Date/Time: Fri, 18 Sep 2026 22:44:35 +0000
TT Problems
View Count: 1024
[2021-02-17 15:56:44]
JGI - Posts: 13
I have an AMP/TT account and am aware of the issues from yesterday. I noticed that my Trade Activity Log [Trades] for that account is still having problems -- the entry/exit prices seem to be off by a factor of 100 (2 decimals), which is throwing off the P&L. Will this correct on its own or do I have to do something? Thanks!
[2021-02-17 16:40:12]
You should remove any duplicate fills by using the Delete Trade Activity Entry command:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log)
Date Time Of Last Edit: 2021-02-17 16:40:26
[2021-02-17 17:13:31]
JGI - Posts: 13
I don't have a problem with duplicate fills, I have a problem because the prices are wrong. For example, my actual entry price for RTYH21 is 2281.00, but the Trade Activity Log has the price at 228100.00 (that's off by a factor of 100). All the entry and exit prices for that AMP/TT account are off like that. What can be done to fix this? Thanks.
[2021-02-17 23:39:18]
The problem is you do not have the right service selected. Follow steps 9 and 10 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
After that in the Trade Activity Log select Edit >> Refresh Log.
[2021-02-19 21:14:45]
JGI - Posts: 13
Hi, if we're on AMP/TT, are we supposed to be switching over to CQG? Thanks!
[2021-02-19 22:28:21]
John - SC Support - Posts: 47939
It is up to you if you want to switch from TT to CQG.
The driving factor is how quickly you want to get trading again. AMP has put a hold on trading through them with TT. You would need to ask them when they expect to lift the hold.
[2021-02-21 21:27:04]
JGI - Posts: 13
I just received an email from AMP saying they will no longer be supporting TT on any exchanges. They are asking that I change from TT to CQG for order routing which I assume means we can continue to use Denali and pay for exchanges through Sierra. Does this change mean I will no longer be using the SC order routing service? And if not is there anything I need to do to cancel it? I have already submitted the form provided by AMP. Thank you!
[2021-02-22 15:45:24]
Yes.
Yes until we have our direct CME order routing available.
No.
