Date/Time: Fri, 02 Oct 2026 16:42:58 +0000
Setting up the Denali Eurex Exchange
View Count: 851
[2021-02-17 15:55:47]
User288770 - Posts: 2
I have started the process of moving from IQ feed to the Denali Eurex Exchange but I don't think I have done it correctly.
When I go into "Chart Settings" I am looking for the symbol "FDAXH21-Eurex" which doesn't seem to be in the list - obviously I must have done something wrong - please can you help?
P.S. I only trade off the DAX Futures so want the same chart functionality that I already have but want to take advantage of SC's Denali feed including the free trial through February.
[2021-02-17 17:23:50]
John - SC Support - Posts: 48091
The first issue is that you have not activated the EUREX exchange. You can do this on this page:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedNonCME
With regards to:
Are you going to Chart >> Chart Settings and then selecting the "Find" button next to the Symbol entry? Are you not seeing the EUREX symbols on that page?
Also, you can just convert your existing symbols to the new ones by selecting Edit >> Translate Symbols to Current Service. Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
