Date/Time: Thu, 16 Jan 2025 17:01:25 +0000
Alerts problem
View Count: 1730
[2014-02-26 11:13:14] |
User63841 - Posts: 4 |
Hi, I am getting problems when i set up alerts, they don't react the same depending on the time frame or type of chart,how can this be fixed ? To be clear i want to have an alert each time the price cross a level (horizontal line or rectangle), i want the alert right away, not at the end of the bar. To do so, i enabled Alert for chart drawing on the chart drawing alert, with the option "Entire bar (H or L) and Crossing. The fact is : - on my 2 min chart, is works fine. - on my 30 min chart, or 1 : i have no sound at all, or 2 : the sound comes at the end of the bar, not when the price cross the line. - on my 30 min Market profile graph : here i have nothing, alerts don't seem to work. Thanks and regards |
[2014-02-26 17:24:33] |
- on my 30 min Market profile graph : here i have nothing, alerts don't seem to work. In the case of a TPO Profile Chart, this is definitely not going to work.- on my 30 min chart, or 1 : i have no sound at all, or 2 : the sound comes at the end of the bar, not when the price cross the line. Make sure the Comparison Precision is set correctly. Really there if there is a problem it would require that you provide us a chart with the drawing and the alert settings, and the very specific time in the chart it does not work when you expect it to and then we can test it.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-22 13:19:59] |
Matt654 - Posts: 73 |
Hi Can anyone advise me how to write an formula alert for TPO Profile. I want an audio alert to sound when it reaches near the extremes of the Profile. I have tried some formulas that work on other studies but they don't seem to work on TPO Profile. Thx Matt
[2017-08-22 13:58:34] |
When what reaches near the extremes of the profile?
[2017-08-22 14:06:27] |
Sorry last price, or last trade arrow (SG20)
Date Time Of Last Edit: 2017-08-22 14:10:24
[2017-08-23 15:27:01] |
We apologize for the delay, we need to do some testing in regards to this.
[2017-11-16 06:38:04] |
Set this formula on the TPO Profile Chart study: OR (C>=H-TICKSIZE*4, C <= L+TICKSIZE*4) Refer to the instructions here: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
