Date/Time: Sun, 23 Feb 2025 14:49:27 +0000
OHLC
View Count: 585
[2021-02-17 13:41:36] |
User148596 - Posts: 217 |
Hi, I have a chart that separates the day and overnight sessions with a volume profile and the "Use extended session" box is checked in chart settings. But, I am trying to get OHLC for the previous RTH session only. Is this possible? |
[2021-02-17 16:33:10] |
John - SC Support - Posts: 38116 |
You can use the Daily OHLC study as it allows you to specify that you only want to use the "Day Session Only" and you can specify a "Reference Days Back". Refer to the information here: Daily OHLC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-17 18:00:04] |
Thanks, that is working, however I can't change from a line to a dash. I selected dash and hit apply. Can't switch it from a line to a dash or dotted line. Thanks! |
[2021-02-17 18:06:40] |
and if I want to do the same thing for the the previous week's OHLC what would the setting be for days back to reference?
[2021-02-17 18:31:23] |
Are you using this with a Study/Price Overlay and you are trying to change the Draw Style on the Study/Price Overlay study? If so, then refer to the following: Study/Price Overlay Study: Use Styles and Widths from Source Study Otherwise, you should not have a problem changing the Draw Style or Line Style. ----------------------------- and if I want to do the same thing for the the previous week's OHLC what would the setting be for days back to reference?
To see the previous Week's OHLC you would need to use the Period OHLC - Variable Period study. Refer to the information here: Previous/Period OHLC-Variable Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
