Date/Time: Sun, 23 Feb 2025 14:05:47 +0000
Upside Down Moving Average
View Count: 588
[2021-02-17 12:43:48] |
Shawn J - Posts: 32 |
Hello. Is there a way to invert the moving average - exponential? I would like to see my moving averages upside down if possible. Thank you!
[2021-02-17 13:25:28] |
Have a look at this page: Using the Basic Arithmetic Studies You can multiply it by -1 or use a formula like 1/Value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-17 14:30:11] |
I've chosen the Study Subgraph Invert based on my preferred Moving Average - Exponential. However, when I select Chart Region 1 (where I prefer the subgraph to be), it does not appear to be present. Is this the right study to invert my moving average?
[2021-02-17 14:37:27] |
John - SC Support - Posts: 38116 |
When you invert the data, you are turning them into very small numbers (1/x). Therefore, the moving average is not being displayed with the main price graph, as the values are somewhere down between 0 and 1. You would need to set the inverted study to have scale of Independent to see it with the Main Price Graph. Refer to the following: Chart Scale and Scale Adjusting: Displaying Multiple Graphs in Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
