Date/Time: Sun, 23 Feb 2025 14:06:06 +0000
Edit stop Type
View Count: 478
[2021-02-17 12:05:42]
58LesPaul - Posts: 429
Could you make it easier to change an active stop? We can change the shares or contracts easily, why couldn't this be done with order type and also trailing stop price level difference? Instead of a 3 point trailing stop, right click on the price label on the active order and be able to change the trail points. Also, right click on the type and change it from a stop to a trailing stop?
[2021-02-17 13:22:47]
The type is not changeable. However, when you adjust the price of the trailing stop, it does adjust the trailing stop offset:
Order Types: Trailing Stop
[2021-02-17 13:56:38]
I guess I should have labeled this topic as a Feature Request. Especially the change order type. Just click on “Stop” on the active order and have a choice to change to Trailing Stop?
