Date/Time: Mon, 24 Feb 2025 00:59:52 +0000
Live Data Feed
View Count: 748
[2021-02-17 11:21:58] |
User810659 - Posts: 8 |
Hi Support I've been trying to open an account with AMP for a live data feed but no success yet. Is there any another way to get live data feed without opening an account with AMP. Regards, Solomon |
[2021-02-17 13:18:08] |
For what exchange do you need real-time data for?
[2021-02-17 13:33:45] |
This real-time data is for SP 500 and Crude oil
[2021-02-17 14:05:04] |
These markets are traded on the CME Group, so you would need a funded trading account to take advantage of nonprofessional fees. So you have to pay the higher priced professional fees instead : Is Historical and Real-time Futures Data Included?: CME Exchange Fees for Professionals and Users Without a Supported Trading Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-17 14:05:20
[2021-02-17 17:53:58] |
Hi I've been trying to open an account with AMP with no success, can I open an account with Dorman Trading still be getting the same service as AMP and my account be linked with Sierra for the live data feed. Is it possible to have a call with you to discuss my concern Kind regards, Solomon |
[2021-02-17 18:18:24] |
John - SC Support - Posts: 38116 |
Any account that allows you to connect to one of our Supported Trading Services will work. We just need to be able to validate your account by having you connect Sierra Chart to it. Refer to the available services here: Supported Data and Trading Services: Supported Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-17 18:18:37
[2021-02-22 10:21:04] |
Hi John, Thank you for your response. Are you saying that I can also use the live data feed provided by Sierra chart for CME and NYMEX (Service package 11 Advanced + Denali Data Feed) without opening a live-funded trading account with one of the clearing firms. If yes, how much is the monthly payment for using the Sierra chart live data feed? Kind regards, Solomon |
[2021-02-22 17:17:54] |
Hi John, can you please keep me posted me on this request? Kind regards, Solomon |
[2021-02-22 20:13:20] |
without opening a live-funded trading account with one of the clearing firms. No, that is not what we are saying. Quite the opposite. In order qualify for the lower-priced Non-Professional exchange fees for the CME Group, you need to have a funded trading account. You can also pay for Professional rate, if you want. The point we are trying to make is that you can have an account with any broker that supports one of the trading services that we support, you are not limited to AMP. The list of trading services is given in the link above.[/quote] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 20:13:32
[2021-02-23 14:31:14] |
You can open an account at Dorman. That will work. Still the easiest method for verifying you have a funded trading account, is to use the Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-23 14:31:43
[2021-02-25 14:55:58] |
Hi John, Can I open an account with Edge Clear do they support your trading services? Kind regards, Solomon |
[2021-02-25 15:19:04] |
Yes that broker supports Sierra Chart.
