Date/Time: Sun, 23 Feb 2025 14:08:21 +0000
Eurex Trading Phillip Capital
View Count: 607
[2021-02-17 10:41:19] |
Chap - Posts: 39 |
Hi, my broker is Phillip Capital - Edge clear. Phillip Capital has not able TT routing services with Eurex. so my alternative will be go with CQG, however with you new policy about EUREX, i wont be able to do that. i appreciate your help, advice and possible solution to be able to trade EUREX. Thanks. |
[2021-02-17 15:52:53] |
John - SC Support - Posts: 38116 |
You can still trade the EUREX using CQG as the trading provider and getting the EUREX data from us. Refer to the information here regarding integrating the Sierra Chart data feeds with your trading service: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
