Date/Time: Wed, 30 Sep 2026 06:56:38 +0000
Server settings clarifying question
View Count: 706
[2021-02-17 00:16:19]
User912281 - Posts: 18
Based on the Direct Message received earlier today regarding the TT issue (Post From: TT Based Order Routing Service: TT Interruption), I understand we need to confirm that at least one of the servers listed on Data/Trade Service Settings tab is Server 1, which is the case (currently assigned as Backup Server).
However the other two servers that are assigned are Servers 2 and 4, which I understand are no longer functional.
Therefore, since this appears to mean I am effectively operating with no backup server, should I change Server 2 and/or 4 to one of the remaining available servers (i.e. 3, 5 or 6)?
And by the way, I am opening this new thread instead of using the "Post From: TT Based Order Routing Service: TT Interruption" because it was locked.
Thank you!
[2021-02-17 15:10:40]
John - SC Support - Posts: 48062
Server 2 is now functional again, so you are fine. But you could change it if you wanted.
