Date/Time: Mon, 28 Sep 2026 15:37:19 +0000
Account
View Count: 823
[2021-02-16 22:28:15]
User960573 - Posts: 15
Hello! I have questions about the subscription to the account.
1. I have an IB account. If I subscribe to package 5, will it give me the opportunity to trade stocks with charts via ib?
2. I have a amp account. If I trade futures, do I need to additionally buy a subscription for the CME exchange, for example?
3. If I combine trading with two brokers, is it enough for me to have a subscription to package 5 and a subscription to exchanges?
4. Package 11 in this case (two brokers) allows me to trade stocks and futures with two brokers?
[2021-02-16 22:40:19]
John - SC Support - Posts: 48032
1. Yes. The package does not matter.
2. It depends on where you will be getting your data from, which is also partially dependent on what trading service you are using. We recommend using our Denali Exchange Data Feed, but you can get data from CQG, if you prefer. Refer to the information here for the Denali Exchange Data Feed:
3. Yes. You can have multiple installations of Sierra Chart on the same computer. For what you are suggesting, we recommend having one installation setup for IB and the other for your Futures Trading. Refer to the information here:
Using Multiple Data and Trading Services at the Same Time
4. Any of the packages will allow you to trade stocks and futures with two brokers. The main thing you will want to determine is whether you need the Basic Package (package 3) or the Advanced Package (Package 5). If you will also be using the Denali Exchange Data Feed, then you should use Package 10, or 11. If you also want to be able to see the MBO data, then that would be Package 12. You will find the descriptions between the packages here:
Description of Service Packages and Pricing: Packages
[2021-02-17 09:17:20]
hello again! Does the site have video clips on how to use the Denali Exchange Data Feed?
[2021-02-17 15:45:55]
In general, we have just a few videos. You will find more by looking online.
We assume you are referring to setting up the Denali Exchange Data Feed, which we do not have any videos for, but there are comprehensive instructions with images here:
