Date/Time: Tue, 26 Nov 2024 03:57:04 +0000
Numbers Bars , 76%-100% color (green or red)
View Count: 1597
[2014-02-26 09:36:03] |
User31408 - Posts: 23 |
Dear all, I ve tried to understand what 76%-100% color means, I tried to read on sierra charts but unfortunately I do not understand exactly the philosophy behind it. Could you please explain me why red color appears with the percentage 76-100% ? If you can give a numerical example I would appreciate a lot. Best regards |
[2014-02-26 09:38:52] |
If forgot to specify "Text on dominant side"
[2014-02-26 09:40:31] |
and also "Text on dominant side auction"
[2014-02-26 09:59:43] |
If I do understand, but I probably not understanding the philosophy. Pease find the attachement. My settings are 75-100% only with Text on Dominant Side Auction. take the following example : why "4312" is colored red ? 4822*100%=4822 so 4312 is not >3616 so why red color ? But probably I am doing wrong, please advise me on it. Regards, |
Dominant Side Auction.jpg / V - Attached On 2014-02-26 09:52:46 UTC - Size: 3.62 KB - 396 views |
[2014-03-30 03:38:38] |
We apologize for the delay with responding. We have gotten behind on the documentation which documents how all of this works. It is now done. This capability is fully supported in Sierra Chart and is known as a Numbers Bars Diagonal Dominant Side coloring. "Diagonal" will be the new term to describe it since it is a very intuitive way to understand rather than the term "auction". Here are the step-by-step instructions to use this feature: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison The percentages can be changed. So you can program any percentage comparisons that you require. The documentation refers to version 1114 terminology. Update Sierra Chart by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:49:46
[2014-03-30 03:45:56] |
Profile Trader - Posts: 174 |
SC Engineering, Has any of the logic/programming changed in release 1114? Or are you just changing "Text on Dominant Side Auction" to Text on Dominant Side Diagonal" Thanks, Doug |
[2014-03-30 03:49:07] |
We gave the wrong link in the prior post. Here is the correct link: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison No logic changes. Just a rename. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
