Date/Time: Fri, 20 Nov 2026 18:37:02 +0000
2019 NG historical spread Scale Units
View Count: 881
| [2021-02-16 20:44:50] |
| User664240 - Posts: 209 |
These values are incorrect, they should be between -40 and plus 40 approximately. They seemingly changed over night. http://www.sierrachart.com/image.php?Image=1613508083937.png |
| [2021-02-16 21:58:37] |
The high is $1.727.... or 1727 ticks not 1727.000. Is there an easy correction for this
| [2021-02-16 22:06:13] |
Under symbol settings for NG nymex spreads you have Price display of .001 and tick size .01000?? This is incongruent. The tick size should equal the price display on all symbols. the tick size should also be .001.
Date Time Of Last Edit: 2021-02-16 22:07:31
| [2021-02-16 22:09:57] |
Here is the chart for the nearby NG H/J spread if this helps. http://www.sierrachart.com/image.php?Image=161351333793.png |
| [2021-03-22 22:56:30] |
The original issue consistently appeared on "HISTORICAL" charts not Real time spread charts. Below in dark back round is the result from the steps you suggested and in the lighter is the result from not updating the symbol. Which has the correct values. Further the original issue was solved by simply changing the Historical Multiplier.
| Attachment Deleted. |
