Date/Time: Tue, 15 Sep 2026 23:12:54 +0000
Subgraph Color Change
View Count: 1588
| [2021-02-16 17:44:09] |
| profitmotive - Posts: 5 |
I am using the Cumulative Delta study and I cannot get the "Close" color to change. The dark red is really hard to see in the spreadsheet and on the chart. How do I change the color? When I pick a color from this menu and click apply it defaults back to the dark red. I uploaded a file because I cannot attach a screenshot. The edit feature is grayed out while in the subgraph menu. |
Private File |
| [2021-02-16 18:32:24] |
| John - SC Support - Posts: 47903 |
Is that really a Study/Price Overlay study that you are using to overlay the Cumulative Delta from another chart? If it is, then the reason you cannot change it is because they are not changeable unless you set the study Inputs to allow changing it. Refer to the following: Study/Price Overlay Study: Use Colors from Source Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-16 18:46:42] |
Thank you for the response. I could not get that fix to work. Please see below. I do not see the option to change the study inputs. Here is a screenshot of the chart with the cumulative delta bars study. http://www.sierrachart.com/image.php?Image=1613500863712.png I also added a screenshot of the study settings and where I looked at the input options |
Private File |
| [2021-02-16 18:49:01] |
Just saw the checkbox on the subgraph.....got it fixed. Thanks |
| [2025-04-12 20:32:47] |
| AC96354 - Posts: 21 |
the same problem, but i didnot understand where find that INPUT
| [2025-04-15 20:46:37] |
AC96354: You have posted from an expired account. If you have another account you are using, then you need to post from that account. Otherwise, we do not give support for expired accounts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
