Date/Time: Wed, 23 Sep 2026 15:00:52 +0000
[Programming Help] - Signal calculation with in the bar
View Count: 923
| [2021-02-16 16:04:26] |
| User61576 - Posts: 458 |
I am attaching a cpp file I found of the delta divergence I am trying to cause the signal (tSetupSubgraph) to appear before the bar is closed (and not as it's now when the signal shows at the end of the bar) but after a minimal amount of volume traded. can someone please guide me on how to do this? thanks! |
| [2021-02-16 16:26:18] |
| norvik_ - Posts: 106 |
This may be done by two ways. You can refer to lower time frame, or make your own inside bar calculations using sc.ReadIntradayRecordsForBarIndexAndSubIndex. First method is a bit easier, second will give you flexibility and full control over each tick.
| [2021-02-17 15:40:04] |
| ForgivingComputers.com - Posts: 1238 |
This if block at line 268 causes the calculations that follow to wait until the bar has closed: if(sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED)
You can try changing it to if(true) and see what happens.
