Date/Time: Sun, 23 Feb 2025 14:31:22 +0000
Merge stops / Target limits for add ons?
View Count: 575
[2021-02-16 15:45:57] |
User199823 - Posts: 6 |
Hello, Is there an easy way when using the chart for trading that when I do addons that I can merge the stops and the target limits so I don't have to juggle adjusting quantities of them? Thanks! |
[2021-02-16 18:01:56] |
John - SC Support - Posts: 38116 |
Refer to the Scaling Out and Scaling In sections starting here: Attached Orders: Scaling Out For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
