Date/Time: Mon, 25 Nov 2024 19:29:55 +0000
Problem With Symbol HBC/HSBC
View Count: 1227
[2014-02-26 09:02:09]
User43787 - Posts: 7
HSBC Holdings plc (UK Bank)
Symbol changed from HBC to HSBC.
Sierra Historical data for has both symbols
2008-05-05 to 2013-11-14 for HBC
2013-11-15 to 2014-02-25 for HSBC
How do I combine the files to see all the data on 1 chart?
[2014-02-26 09:12:37]
Historical Daily chart or Intraday chart are you referring to?
In the case of a Historical Daily chart you can simply do cutting and pasting between the files. You can access the data through Edit >> Edit Data-Historical Chart.
Or you can rename the chart data file from HSB to HSBC. Refer to documentation here:
https://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#RenamingFiles
Date Time Of Last Edit: 2014-02-26 09:14:10
[2014-02-27 12:06:05]
Intraday chart.
I was a little bit leery about renaming files because I did not know if you had a configuration file somewhere that keeps track of all the files and renaming one of them might cause a problem.
I disconnected from the data feed, renamed the HSBC file to something else to avoid a name conflict, renamed the HBC file to HSBC, reconnected to the data feed and it updated the file, that worked.
Thank you.
[2014-02-27 18:20:09]
No. It is completely safe to do this in Sierra Chart. Sierra Chart is very well engineered and does not have a poor design like this.
