Date/Time: Sun, 23 Feb 2025 14:06:50 +0000
Lock countdown timer in place horizontally
View Count: 555
[2021-02-16 14:55:58] |
User845052 - Posts: 75 |
If you could lock it the way you can stationary text. Thanks |
[2021-02-16 17:33:35] |
John - SC Support - Posts: 38116 |
We do not understand your request. This is exactly how it currently works. The Countdown timer stays in a fixed position on your screen and does not move when scroll through the bars. The only time this is not true is if you have the option for Use Current Price as Vertical Position set to Yes. Refer to the information here: Countdown Timer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-16 17:33:52
[2021-02-16 19:17:41] |
That's correct. I just realized you had to reload the study (Hide>Unhide or Load Saved) for the adjustment to show.
