Date/Time: Sun, 23 Feb 2025 14:26:39 +0000
Time Range Highlight Transparent and Time Line Studies on the TPO chart
View Count: 587
[2021-02-16 13:25:45]
RIFT - Posts: 124
The "Time Range Highlight Transparent" study does not work properly when using 3 session (Letters in Own Column and Standard Profile) on the TPO chart. Time Line study is also incorrect, London is double. See screenshot 1.) If I do "Reload and Recalculete" then it is okay, but I have to do it every time I do something on tpo chart. See screenshot 2.)
Can you please correct?
Thx!
Best
image1.).png / V - Attached On 2021-02-16 13:25:06 UTC - Size: 171.34 KB - 198 views
image2.).png / V - Attached On 2021-02-16 13:25:12 UTC - Size: 165.3 KB - 202 views
[2021-02-17 08:13:55]
Those studies definitely cannot be used on that chart.
Refer to:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
Date Time Of Last Edit: 2021-02-17 08:14:26
