Date/Time: Sun, 23 Feb 2025 14:49:15 +0000
FDXM - mini DAX intra day data not downloading
View Count: 533
[2021-02-16 09:49:55]
vish100 - Posts: 111
I am getting an error as below for mini DAX futures intraday charts. Data is downloading until 28th Jan 2021
"Download Failed
Error downloading historical intraday
data for FDXMH21_FUT_Eurex.. Historical data logon error:
Data files folder not set for service code: eurex | username: xxx"
File attached. I have both SC exchange data feed and Denali enabled.
It was working fine 2 months ago. I took a break from trading and when I returned I am getting this error.
I am also using SC futures order routing service and AMP is the broker
Please can you help
Thx
Date Time Of Last Edit: 2021-02-16 09:50:37
imageSC DAX error.jpg / V - Attached On 2021-02-16 09:49:18 UTC - Size: 85.95 KB - 202 views
[2021-02-16 10:05:16]
You need to update to version 2230:
[2021-02-16 11:03:46]
I have updated but now I am getting 15 min delayed feed only.
Could you help a bit further?
thx
[2021-02-16 11:06:37]
Yes that does make sense. If you require real-time data you need to activate the EUREX exchange here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX
There is no cost for it for this month.
Date Time Of Last Edit: 2021-02-16 11:07:26
[2021-02-16 11:23:16]
Thanks its working now!
However I guess I activated too many feeds which I may not need. I activated Denali, SC Exchange Data feed and DenaliEUREX.
Can I cancel SC Exchange data feed - or do I need it for mini DAX?
thanks
[2021-02-16 11:31:54]
We did this for you and have now issued you a refund for that.
Date Time Of Last Edit: 2021-02-16 11:33:34
