Date/Time: Thu, 24 Sep 2026 04:32:21 +0000
have sent analysis a/c 105980 keeps disconnecting
View Count: 771
| [2021-02-16 07:34:23] |
| User946492 - Posts: 7 |
have sent analysis a/c105980 keeps disconnecting
| [2021-02-16 16:08:45] |
| John - SC Support - Posts: 47994 |
You are getting the following errors: Error getting address info for api.cqg.com. Windows error code 11001: No such host is known.
It looks like your computer is having a problem with the Domain Name Service (DNS) and is not able to find the IP address properly. This is not a Sierra Chart issue, but is a local network issue on your side. We do not know why you would be having this issue. Try restarting your computer. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-17 00:04:11
