Date/Time: Sun, 23 Feb 2025 18:24:58 +0000
chart books
View Count: 1692
[2021-02-18 16:50:46]
User906585 - Posts: 35
ok so this is the steps i took. all steps were the same and reason of why i am confused of why only one chart book of the ones i downloaded is in sierra chartbooks. All charts are from same person. download> pc> Cdrive> Sierra > data and that is were the files were placed
[2021-02-18 17:25:05]
John - SC Support - Posts: 38116
Now, when you select File >> Open Chartbook, are you able to see the chartbooks that you copied into the Data folder?
Is it just the 2 that you attached above that you copied into your data folder? If you are only seeing one of them, which one do you see and/or which one do you not see?
[2021-02-18 17:51:27]
i downloaded many. and only one is there. I did not sent u the file that is showing in sierra chartbooks since there are no issues with that one. I downloaded over 10 chartbooks and i have more but stopped after i realized they were not available once i open chartbooks
[2021-02-18 19:07:02]
Please verify that your phone number is correct on this page:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
And let us know when we can call and connect to your system so we can see what you are seeing.
[2021-02-18 19:22:18]
yes it is
[2021-02-18 20:03:14]
We tried calling but just got a voicemail. Let us know if there is a specific time we should call.
[2021-02-18 20:04:11]
sorry i missed ur call. can u try right now please
[2021-02-18 20:22:15]
Calling in about 20 seconds.
[2021-02-18 20:38:31]
Talked to customer. The data was stored in a PCloud online storage, and somehow he was downloading pcloud files rather than the Chartbooks. Showed him how to download the Chartbooks themselves and put them in the correct folder.
Date Time Of Last Edit: 2021-02-22 15:33:35
