Date/Time: Sun, 23 Feb 2025 14:13:05 +0000
IQFeed for Market depth support
View Count: 536
[2021-02-15 22:38:20] |
$tack - Posts: 95 |
Are there any limitations to using IQFeed for Market depth with SP500 emini futures? I have the permissions enabled with iqfeed. Are there limits for example in terms of number of levels of depth or things like any known performance issues wtih SC and IQfeed? Thanks |
[2021-02-16 12:09:10] |
No limitations that we are aware of or performance issues. In the case of CME Group futures streaming data and market depth data we do recommend using this data feed instead: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
