Date/Time: Mon, 25 Nov 2024 14:34:22 +0000
Running Windows on MacOS w/ Parallels - File compression error
View Count: 786
[2021-02-15 20:38:25]
User199823 - Posts: 6
In my message log I receive the error:
File compression not supported on file system. \\Mac\Hom\Desktop\Sierrchart2230\Data\F.US.M2KH21.SCID. Windows error code 1: Incorrect Function. Anybody run into this issue?
[2021-02-15 21:33:54]
That is not unusual. Just make sure you are running the latest version of Sierra Chart so it does not open the Sierra Chart Message Log. If it does let us know.
Date Time Of Last Edit: 2021-02-15 21:34:10
[2024-02-24 00:29:34]
jibbs - Posts: 1
IM having this same issue, verified I have the current version, 2604.
[2024-02-24 06:15:54]
Sierra_Chart Engineering - Posts: 17173
Disable these two compression options:
Advanced Service Settings: Support Intraday and Market Depth Files Compression (Global Settings >> Advanced Service Settings >> Other) (This one and the following one)
