Date/Time: Sun, 23 Feb 2025 08:41:54 +0000
Filter for the Markets orders
View Count: 620
[2021-02-15 17:34:34] |
User657945 - Posts: 226 |
I think you should consider a filter mdoficable by the user to set the size to visualize otherwise for products like INterst rate derivative i.s FGBL , OAT the quantitly it is so much that is impossibile to use the dom for more than 20 min then you go crazy. So two option: 1) a filter and you can see only the order >than the size or 2) a filter that let you highlight with a diff color or character size the bigger orders. Attahced a snapshot of FGBL |
[2021-02-15 20:00:03] |
Yes this is available: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-15 20:31:48] |
THX a lot of new things I missed
