Date/Time: Sun, 23 Feb 2025 08:41:54 +0000
DTC to SC Futures Order Routing
View Count: 461
[2021-02-15 16:35:49]
User868204 - Posts: 2
How do I get the service changed from DTC to SC Futures Order Routing? It says Read Only and won't let me select anything else. Am I jumping the gun?
[2021-02-15 17:56:54]
John - SC Support - Posts: 38116
You are in a Sub-Instance when you see that, and that cannot be changed in a Sub-Instance. The Sub-Instance is connected to the main instance and trades using the settings that are setup in the Main instance. Refer to the information here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method)
[2021-02-15 19:58:43]
Yes you need to make the Current Selected Service change within the main instance of Sierra Chart. Not a sub instance.
Date Time Of Last Edit: 2021-02-15 19:58:54
