Date/Time: Sun, 23 Feb 2025 08:29:14 +0000
Regards package
View Count: 575
[2021-02-15 16:23:59]
trent johansen - Posts: 1
Hey guys I was looking at the 35 usd a month package ? Is that correct ? As I’m just looking at trading 5 instruments atm as I’m doing a course through G7fx ? Not sure if you’ve heard of them ? But primarily going to be trading futures , S&P 500 , 10 year treasury, crude oil , EUR , and GBP futures . Not sure if that information helps ? And I’ll just be using the simulator for now until I’m ready to trade live . Looks forward to your response 👍
[2021-02-15 17:36:18]
John - SC Support - Posts: 38116
To begin with, refer to the following information for the differences in the packages and determine which one you need:
Description of Service Packages and Pricing: Packages
If you are just wanting to test, then we recommend using the Delayed Exchange Data Feed, which gives you streaming data from the CME Group, just delayed by 10 minutes and 10 seconds, otherwise it acts just like live data. This data is free with any Sierra Chart package. If you go this way, then you would just need package 3 or 5. Refer to the following:
