Date/Time: Sun, 23 Feb 2025 08:43:05 +0000
Chart DOM ASk and Bid Market orders
View Count: 590
[2021-02-15 13:12:06] |
User657945 - Posts: 226 |
Hi may be I'm missing something but I tried to get visibility of the markets orders on Eurex but I got an empty coloumn. I selected the subscribe market by order data to yes and to support downloading martket depth and I should get visibility of the orders greater than 10 but that's not the case. thx |
[2021-02-15 14:13:47] |
You should see all orders with a quantity of 2 and greater for the EUREX. We are checking on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-15 14:13:53
[2021-02-15 14:43:15] |
I have the market depth graph working fine may be I did not select something but the coloumn of market orders is empty.
[2021-02-15 14:48:28] |
We definitely do see the data: http://www.sierrachart.com/image.php?Image=1613400493987.png Here is the relevant documentation: Market By Order Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-15 14:48:44
[2021-02-15 14:55:23] |
I believe you but mine is empty? what I missed? I Found I did not disconneted and reconneted to datafeed it works
Date Time Of Last Edit: 2021-02-15 14:57:05
