Date/Time: Mon, 24 Feb 2025 03:14:18 +0000
[User Discussion] - replay questions
View Count: 548
[2021-02-15 09:50:08]
User61576 - Posts: 445
1. if I run few different algorithms as different studies, does it affect the speed of the backtesting replay?
2.if I have different studies/algorithms on 2 different charts to test different settings, both on the same time frame, if I select the "all charts in chartbook" is it more efficient to test like this (each chart with a different sim account)?
3. is there any visual way to view the results of the replay?
4. when replaying multiply charts in the same chartbook, and after reading here https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode I still don't understand clearly what is the impact of setting the value of "Processing Step In Seconds" to 1 second vs. 200 seconds. - I am testing 1 min bars but the logic is based on bid/ask volume.
5. what will be the fastest way to get accurate backtesting?
6. will the answer be different if I use volume/delta charts (same for all chart books)?
Date Time Of Last Edit: 2021-02-15 15:33:13
[2021-02-19 21:33:31]
[2021-03-03 08:34:13]
