Date/Time: Mon, 25 Nov 2024 18:42:40 +0000
Chart Settings: saving as default
View Count: 1555
[2014-02-25 23:56:58] |
Fxxtrader - Posts: 79 |
Hello, when making changes to Advanced Settings and Advanced Settings 2, how do I save it as a default setting?
[2014-02-26 06:31:59] |
Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-04 22:05:56] |
Hi, in chart settings, when selecting Historical Chart and choosing Days = 1: what is the start and end time of this daily bar? How come in this setting I can't get the CountDown Timer tool to work? Thanks in advance. Date Time Of Last Edit: 2014-03-04 22:11:18
[2014-03-04 22:15:59] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails12.html What would the Countdown Timer show for a chart consisting of one day per bar when the session times are not known? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-04 22:21:08] |
It would show the remaining time left in the bar, from that I would have been able to learn when the end and beginning of the bar is. Regardless of the start and end time being known, how come the CountDown Timer does not work on this chart setting? It's a useful tool, was wondering, is it an intraday chart tool, only? I will read the contents on the link, again. |
[2014-03-05 17:24:29] |
The Countdown Timer is not going to be meaningful on a Historical Daily chart. It usually is only used with Intraday charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
