Date/Time: Sat, 19 Sep 2026 22:26:30 +0000
[User Discussion] - using OOP clases for studies and trading systems
View Count: 909
| [2021-02-14 20:14:44] |
| User30743 - Posts: 399 |
Is anybody using the oop approach when building studies and trading system? I can see that most (if not all the examples) are procedural style code, which is ok for simple things but I find it quite messy for more complex stuff and generally I like having things encapsulated in classes (Java deformation), so I am thinking of refactoring the code into OOP. But I have not tested anything yet and I don't know what kind of caveats it can have. Any suggestions on this topic? Date Time Of Last Edit: 2021-02-14 20:15:29
| [2021-02-14 21:45:53] |
| User99735 - Posts: 234 |
Hi, I have been using std classes like std::map without any issues. So my advice would be that custom classes can also be used. Regards Vivek |
| [2021-02-15 10:22:28] |
yeah, sure, I am using std:: a lot. I mean custom classes - I have for example a Logger class, or class handling DB connections etc. I would also like to wrap the system logic into a class
| [2021-02-17 15:19:44] |
Other custom classes can be used while taking care of threading issues, ie with DB Connections etc.
| [2021-02-17 16:29:03] |
does sierra work ok with threaded code?
| [2021-02-17 17:01:06] |
| norvik_ - Posts: 106 |
Yes it works fine. If you need to to do some heavy things or endless loop, it can be executed in the separate thread.
