Date/Time: Sun, 23 Feb 2025 08:36:50 +0000
no real time data
View Count: 679
[2021-02-14 18:21:48]
User429467 - Posts: 3
i can see only the delayed data !!
i did everything according the instructions to do it through the "global settings"
i disconnected it and after a few minutes tried to reconnect again
in the window of "sc data - all services "
appears only (intraday download interval for non real time symbols (min)
and the value is "0"
pls advise
Date Time Of Last Edit: 2021-02-14 19:04:09
[2021-02-14 19:03:53]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
