Date/Time: Sun, 23 Feb 2025 21:42:31 +0000
GDIExample.cpp does not compile on remote build.
View Count: 608
[2021-02-14 12:57:09] |
Nicolas Hervé - Posts: 14 |
GDIExample.cpp does not compile on remote build with SierraChart 2229 (even after adding the scDLLName). And it neither does with default settings of Visual Studio downloaded through sierrachart. -- Starting remote build of Custom Studies Source files: GDIExample.cpp. 64-bit -- 13:54:56
Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: /usr/bin/x86_64-w64-mingw32-ld: /tmp/ccVWtb8I.o:GDIExample.cpp:(.text+0x15): undefined reference to `__imp_CreateSolidBrush' /usr/bin/x86_64-w64-mingw32-ld: /tmp/ccVWtb8I.o:GDIExample.cpp:(.text+0x1c): undefined reference to `__imp_SelectObject' /usr/bin/x86_64-w64-mingw32-ld: /tmp/ccVWtb8I.o:GDIExample.cpp:(.text+0x46): undefined reference to `__imp_Rectangle' /usr/bin/x86_64-w64-mingw32-ld: /tmp/ccVWtb8I.o:GDIExample.cpp:(.text+0x63): undefined reference to `__imp_DeleteObject' collect2: error: ld returned 1 exit status -- End of Build -- 13:55:00 |
[2021-02-16 17:09:36] |
We will test this as soon as possible.
[2021-02-19 03:09:38] |
This is now resolved. Try the Remote Build again. We do not see why using Visual C++ would be an issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-23 08:25:59] |
Thanks, issue with Visual C++ will be another topic. I think it is because of some searching path on my windows. I'll open another ticket if needed. |
