Date/Time: Sun, 23 Feb 2025 14:40:52 +0000
sc.AddAndManageSingleTextUserDrawnDrawingForStudy some issues when duplicating
View Count: 573
[2021-02-13 18:21:08] |
@sstfrederik - Posts: 406 |
Hi, I just ran across an issue with this function: sc.AddAndManageSingleTextUserDrawnDrawingForStudy For a quick demo on what I mean we can use the "Clock - RealTime" study which used this function. -1- add first instance of Clock study (click OK); -2- duplicate a second instance from the first Clock study; Set a different pos; (click OK); Second study text is not visible. -3- remove first study instance; Click OK; Second becomes visible; -4- remove second study instance; Click OK; The text plot remains visible on the chart; When a second study is added (step 2) like a new study and not duplicated there is no issue. I would appreciate it if this can be checked and fixed so duplicated study instances will work the same. Thanks, Frederik |
[2021-02-13 23:03:57] |
We will look into this and get it resolved.
[2021-02-16 17:09:51] |
This is resolved in the latest release.
