Date/Time: Sun, 23 Feb 2025 08:39:06 +0000
Getting ver#2144 No longer Supported Message
View Count: 491
[2021-02-13 15:48:32]
User940772 - Posts: 76
I use an instance of Sierra version # 2144 because some of my 3rd party addon's have been slow to update and don't work with current versions of Sierra. Version 2144 was the last they worked with. Today I received a message that 2144 was no longer supported and cannot connect to my feed. Is this correct or is there a mistake somewhere that needs to be fixed? If not, are there any options open to me. Thanks.
[2021-02-13 16:23:29]
Yes we did put out a required update for Transact users. In your case though it should not apply because you have a direct Sierra Chart account.
Can you tell us who the third-party add-ons are from and we can help them recompile the studies. It should be very easy.
[2021-02-14 04:57:44]
You will now be able to use version 2144. Let us know if you cannot.
You just need to restart Sierra Chart.
Date Time Of Last Edit: 2021-02-14 04:58:27
