Date/Time: Sun, 23 Feb 2025 08:29:54 +0000
Spreadsheet 2 does not update?
View Count: 413
[2021-02-12 20:05:14]
Dyoung - Posts: 11
Hi: I have been working with the spreadsheets for a trading system using the "Spreadsheet system for Trading". The formula source sheet is defined as "2". The chart number for the system as this time is sheet 7 because that is the number of the chart. The question: I have noticed that the values in sheet 2 are not updating, but the values in sheet 7 are updating. There are values in sheet 2 but they stopped on 2/5/21 (today is 2/12/21). I could not find the answer in the documentation. Is this normal or is there a problem? Thanks in advance for an answer.
[2021-02-12 20:41:58]
John - SC Support - Posts: 38116
This is normal. Since the formula sheet is defined by Number as 2, then that means that Sheet2 is being used for formulas. But, if there was a chart at some point, that had a Spreadsheet Study on it, then that would have used Sheet2 for its data.
There is not a problem as long as you do not have Chart 2 using the same spreadsheet at some point and you are not wanting the same formulas.
You will find the information regarding this here:
Spreadsheet Study Inputs: Formula Source Sheet Number
