Date/Time: Sun, 23 Feb 2025 09:01:34 +0000
Professional account question
View Count: 461
[2021-02-12 16:02:57] |
S-A-77 - Posts: 20 |
Hi, I was wondering if it is possible to be untagged as a professional account as I don't currently have any active data feeds and I am looking to get funded by a prop firm which will be providing me with the data feeds and a futures account.
[2021-02-12 16:44:39] |
John - SC Support - Posts: 38116 |
If you are getting your data elsewhere, then your status does not matter, as that is only important to determine which CME exchange(s) you will pay for. But, if you want to go through the process to change this with us, then you would need to fill out the Denali Exchange Data Feed Agreements again, but this time you will need to specify your Brokerage and you trading account number. You will find the documents here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
