Date/Time: Sun, 23 Feb 2025 08:44:57 +0000
Windows Error caused data disconnect
View Count: 393
[2021-02-12 15:20:31]
User645429 - Posts: 4
Good afternoon,
After a few hours trading data disconnected and message log stated windows error code 10060. Message log is attached. I have restarted SC but still have same issue and cannot connect to DATA. Thanks
Reading Internal Order ID file. | 2021-02-11 21:35:55.838
Reading Trade Orders file. | 2021-02-11 21:35:55.942
Reading Trade Positions file. | 2021-02-11 21:35:55.943
Reading Trade Account Data files. | 2021-02-11 21:35:55.943
UDPListener (1492). Port 22904 | Listening on UDP port 22904. | 2021-02-11 21:35:55.962
Software version: 2225 64-bit | 2021-02-11 21:35:55.962
Primary Thread ID: 6860 | 2021-02-11 21:35:55.962
Usage end date: 2021-03-05 | 2021-02-11 21:35:55.962
Enabled for: Advanced Features 2. | 2021-02-11 21:35:55.962
Enabled for: Sierra Chart Historical Data Service. | 2021-02-11 21:35:55.962
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-11 21:35:55.962
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-11 21:35:55.962
Enabled for exchange2: CME (Trading Account Required) | 2021-02-11 21:35:55.962
Enabled for exchange2: CBOT (Trading Account Required) | 2021-02-11 21:35:55.962
Enabled for exchange2: COMEX (Trading Account Required) | 2021-02-11 21:35:55.962
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-02-11 21:35:55.962
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-11 21:35:55.962
Current selected Data/Trading service: CQG WebAPI | 2021-02-11 21:35:55.962
Custom symbol settings values: enabled | 2021-02-11 21:35:55.962
Chart Update Interval: 500 | 2021-02-11 21:35:55.962
Intraday Data Storage Time Unit: 0 | 2021-02-11 21:35:55.962
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-11 21:35:55.962
2021-02-12 03:35:55 Local computer time in UTC | 2021-02-11 21:35:55.962
2021-02-11 21:35:55 Local computer time in SC Time Zone | 2021-02-11 21:35:55.962
2021-02-12 03:35:55 Server time in UTC | 2021-02-11 21:35:55.962
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-02-11 21:35:55.962
Program path: C:\SierraChart\ | 2021-02-11 21:35:55.962
Data Files path: C:\SierraChart\Data\ | 2021-02-11 21:35:55.962
OS Version Number: 10.0 | 2021-02-11 21:35:55.962
Locale Setting: C | 2021-02-11 21:35:55.962
DLLs: CandleTaper_64 (1).dll, DivergenceDetector_64.dll, DynamicStopLoss_64.dll, EdgeTradingGroup.dll, EdgeTradingGroup_64.dll, emini-player_64 (1).dll, EminiPlayerIntradaySuite_64 (2).dll, EndedAuction_64.dll, ETG Audio.dll, ETOFSv2.0.dll, ETOFSv2.0_64.dll, ETOFSv3_64.dll, ExahustionDetector_64.dll, JoboPinch_64.dll, LinearRegressionLocation_64.dll, openal32.dll, PivotLine_64.dll, PoorStructure_64.dll, PrevReferences_64.dll, PriceTickDivergence_64.dll, ProfilePeriods_64.dll, ProfileValue_64.dll, ReconstructedTape_64.dll | 2021-02-11 21:35:55.963
Allowed protected custom studies: EMiniPlayer, EminiPlayer Intraday Suite, Emoji Trading Order Flow Suite v2, ETG, ETG Audio, Pit - Candle Taper, Pit - Divergence Detector, Pit - Dynamic Stop Loss, Pit - Ended Auction, Pit - Exahustion Detector, Pit - Jobo Pinch, Pit - Linear Regression Location, Pit - Pivot Line, Pit - Poor Structure, Pit - Previous References, Pit - Price Tick Divergence, Pit - Profile Periods, Pit - Profile Value, Pit - Reconstructed Tape, Pit - Statistics Bubbles, Pit - Tick Statistics, Pit - Volume Comparison, Pit - Volume Ticker Comparison, SST_FreeBundle, VerbalJournal | 2021-02-11 21:35:55.963
Created the DTC Protocol server. | 2021-02-11 21:35:55.980
DTC Protocol Server listening on port 11099. | 2021-02-11 21:35:55.981
Created the DTC Protocol historical data server. | 2021-02-11 21:35:55.981
HD Server Manager | Listening on port 11098 | 2021-02-11 21:35:55.982
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2021-02-11 21:35:55.982
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-02-11 21:35:55.997
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-02-11 21:35:56.298
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-02-11 21:35:56.298
Received 5 login tokens. | 2021-02-11 21:35:56.921
Symbol settings MD5 received. Request ID: 1. | 2021-02-11 21:35:57.326
Symbol settings are up-to-date for cqg. | 2021-02-11 21:35:57.326
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:36:03.441
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:36:03.441
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:36:03.442
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:36:03.443
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:36:03.443
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:36:24.472 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:36:24.473
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:36:24.473
CQG WebSocket | WebSocket closed. | 2021-02-11 21:36:24.473
CQG WebAPI | WebSocket closed. | 2021-02-11 21:36:24.473
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:36:24.473
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:36:24.473
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:36:24.473
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:36:24.488
CQG WebAPI | Disconnected. | 2021-02-11 21:36:24.488
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:36:24.489
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:36:27.489
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:36:27.489
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:36:27.490
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:36:27.491
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:36:27.491
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:36:48.532 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:36:48.532
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:36:48.532
CQG WebSocket | WebSocket closed. | 2021-02-11 21:36:48.532
CQG WebAPI | WebSocket closed. | 2021-02-11 21:36:48.532
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:36:48.532
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:36:48.532
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:36:48.532
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:36:48.548
CQG WebAPI | Disconnected. | 2021-02-11 21:36:48.548
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:36:48.549
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:36:51.534
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:36:51.534
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:36:51.535
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:36:51.535
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:36:51.535
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:37:12.577 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:37:12.577
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:37:12.577
CQG WebSocket | WebSocket closed. | 2021-02-11 21:37:12.577
CQG WebAPI | WebSocket closed. | 2021-02-11 21:37:12.577
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:37:12.577
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:37:12.577
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:37:12.577
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:37:12.592
CQG WebAPI | Disconnected. | 2021-02-11 21:37:12.593
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:37:12.593
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:37:15.584
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:37:15.584
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:37:15.797
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:37:15.797
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:37:15.797
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:37:36.833 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:37:36.834
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:37:36.834
CQG WebSocket | WebSocket closed. | 2021-02-11 21:37:36.834
CQG WebAPI | WebSocket closed. | 2021-02-11 21:37:36.834
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:37:36.834
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:37:36.834
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:37:36.834
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:37:36.849
CQG WebAPI | Disconnected. | 2021-02-11 21:37:36.850
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:37:36.850
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:37:39.847
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:37:39.848
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:37:39.848
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:37:39.849
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:37:39.849
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:38:00.891 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:38:00.891
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:38:00.891
CQG WebSocket | WebSocket closed. | 2021-02-11 21:38:00.891
CQG WebAPI | WebSocket closed. | 2021-02-11 21:38:00.891
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:38:00.891
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:00.891
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:38:00.891
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:38:00.906
CQG WebAPI | Disconnected. | 2021-02-11 21:38:00.907
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:00.907
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:38:03.894
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:38:03.894
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:38:03.895
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:38:03.896
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:38:03.896
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:38:24.919 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:38:24.920
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:38:24.920
CQG WebSocket | WebSocket closed. | 2021-02-11 21:38:24.920
CQG WebAPI | WebSocket closed. | 2021-02-11 21:38:24.920
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:38:24.920
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:24.920
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:38:24.920
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:38:24.935
CQG WebAPI | Disconnected. | 2021-02-11 21:38:24.936
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:24.936
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:38:27.932
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:38:27.932
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:38:27.933
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:38:27.933
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:38:27.933
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:38:48.971 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:38:48.972
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:38:48.972
CQG WebSocket | WebSocket closed. | 2021-02-11 21:38:48.972
CQG WebAPI | WebSocket closed. | 2021-02-11 21:38:48.972
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:38:48.972
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:48.972
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:38:48.972
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:38:48.987
CQG WebAPI | Disconnected. | 2021-02-11 21:38:48.988
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:38:48.988
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:38:51.988
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:38:51.988
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:38:51.989
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:38:51.989
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:38:51.989
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:39:13.053 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:39:13.054
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:39:13.054
CQG WebSocket | WebSocket closed. | 2021-02-11 21:39:13.055
CQG WebAPI | WebSocket closed. | 2021-02-11 21:39:13.055
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:39:13.055
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:39:13.055
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:39:13.055
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:39:13.069
CQG WebAPI | Disconnected. | 2021-02-11 21:39:13.070
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:39:13.070
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:39:16.074
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:39:16.074
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:39:16.075
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:39:16.075
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:39:16.075
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:39:37.106 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:39:37.107
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:39:37.107
CQG WebSocket | WebSocket closed. | 2021-02-11 21:39:37.107
CQG WebAPI | WebSocket closed. | 2021-02-11 21:39:37.107
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:39:37.107
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:39:37.107
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:39:37.107
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:39:37.122
CQG WebAPI | Disconnected. | 2021-02-11 21:39:37.122
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:39:37.123
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:39:40.113
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:39:40.113
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:39:40.114
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:39:40.114
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:39:40.114
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:40:01.163 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:40:01.163
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:40:01.163
CQG WebSocket | WebSocket closed. | 2021-02-11 21:40:01.163
CQG WebAPI | WebSocket closed. | 2021-02-11 21:40:01.163
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:40:01.163
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:01.163
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:40:01.163
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:40:01.179
CQG WebAPI | Disconnected. | 2021-02-11 21:40:01.180
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:01.181
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:40:04.183
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:40:04.183
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:40:04.184
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:40:04.184
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:40:04.184
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:40:25.222 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:40:25.222
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:40:25.222
CQG WebSocket | WebSocket closed. | 2021-02-11 21:40:25.222
CQG WebAPI | WebSocket closed. | 2021-02-11 21:40:25.222
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:40:25.222
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:25.222
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:40:25.222
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:40:25.238
CQG WebAPI | Disconnected. | 2021-02-11 21:40:25.238
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:25.239
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:40:28.259
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:40:28.259
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:40:28.260
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:40:28.261
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:40:28.261
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:40:49.323 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:40:49.324
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:40:49.324
CQG WebSocket | WebSocket closed. | 2021-02-11 21:40:49.324
CQG WebAPI | WebSocket closed. | 2021-02-11 21:40:49.324
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:40:49.324
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:49.324
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:40:49.324
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:40:49.339
CQG WebAPI | Disconnected. | 2021-02-11 21:40:49.340
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:40:49.340
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:40:52.346
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:40:52.346
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:40:52.348
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:40:52.348
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:40:52.348
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:41:13.396 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:41:13.397
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:41:13.397
CQG WebSocket | WebSocket closed. | 2021-02-11 21:41:13.397
CQG WebAPI | WebSocket closed. | 2021-02-11 21:41:13.397
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:41:13.397
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:41:13.397
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:41:13.397
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:41:13.412
CQG WebAPI | Disconnected. | 2021-02-11 21:41:13.413
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:41:13.413
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:41:16.418
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:41:16.418
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:41:16.419
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:41:16.420
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:41:16.420
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:41:37.447 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:41:37.449
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:41:37.449
CQG WebSocket | WebSocket closed. | 2021-02-11 21:41:37.449
CQG WebAPI | WebSocket closed. | 2021-02-11 21:41:37.449
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:41:37.449
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:41:37.449
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:41:37.449
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:41:37.462
CQG WebAPI | Disconnected. | 2021-02-11 21:41:37.463
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:41:37.463
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:41:40.464
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:41:40.464
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:41:40.465
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:41:40.466
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:41:40.466
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:42:01.513 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:42:01.514
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:42:01.514
CQG WebSocket | WebSocket closed. | 2021-02-11 21:42:01.514
CQG WebAPI | WebSocket closed. | 2021-02-11 21:42:01.514
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:42:01.514
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:01.514
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:42:01.514
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:42:01.529
CQG WebAPI | Disconnected. | 2021-02-11 21:42:01.530
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:01.530
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:42:04.517
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:42:04.518
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:42:04.519
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:42:04.519
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:42:04.519
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:42:25.551 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:42:25.552
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:42:25.552
CQG WebSocket | WebSocket closed. | 2021-02-11 21:42:25.552
CQG WebAPI | WebSocket closed. | 2021-02-11 21:42:25.552
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:42:25.552
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:25.552
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:42:25.552
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:42:25.567
CQG WebAPI | Disconnected. | 2021-02-11 21:42:25.567
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:25.568
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:42:28.570
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:42:28.571
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:42:28.808
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:42:28.808
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:42:28.808
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:42:49.861 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:42:49.862
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:42:49.862
CQG WebSocket | WebSocket closed. | 2021-02-11 21:42:49.862
CQG WebAPI | WebSocket closed. | 2021-02-11 21:42:49.862
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:42:49.862
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:49.862
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:42:49.862
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:42:49.877
CQG WebAPI | Disconnected. | 2021-02-11 21:42:49.878
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:42:49.878
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:42:52.889
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:42:52.889
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:42:52.890
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:42:52.891
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:42:52.891
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:43:13.940 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:43:13.940
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:43:13.940
CQG WebSocket | WebSocket closed. | 2021-02-11 21:43:13.940
CQG WebAPI | WebSocket closed. | 2021-02-11 21:43:13.940
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:43:13.940
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:43:13.940
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:43:13.941
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:43:13.956
CQG WebAPI | Disconnected. | 2021-02-11 21:43:13.956
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:43:13.957
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:43:16.958
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:43:16.958
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:43:16.959
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:43:16.959
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:43:16.959
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:43:37.979 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:43:37.980
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:43:37.980
CQG WebSocket | WebSocket closed. | 2021-02-11 21:43:37.980
CQG WebAPI | WebSocket closed. | 2021-02-11 21:43:37.980
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:43:37.980
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:43:37.980
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:43:37.980
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:43:37.995
CQG WebAPI | Disconnected. | 2021-02-11 21:43:37.995
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:43:37.995
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:43:40.993
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:43:40.993
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:43:40.994
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:43:40.995
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:43:40.995
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:44:02.050 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:44:02.050
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:44:02.050
CQG WebSocket | WebSocket closed. | 2021-02-11 21:44:02.050
CQG WebAPI | WebSocket closed. | 2021-02-11 21:44:02.050
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:44:02.050
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:02.050
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:44:02.050
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:44:02.064
CQG WebAPI | Disconnected. | 2021-02-11 21:44:02.064
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:02.064
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:44:05.075
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:44:05.076
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:44:05.076
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:44:05.077
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:44:05.077
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:44:26.112 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:44:26.113
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:44:26.113
CQG WebSocket | WebSocket closed. | 2021-02-11 21:44:26.113
CQG WebAPI | WebSocket closed. | 2021-02-11 21:44:26.113
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:44:26.113
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:26.113
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:44:26.113
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:44:26.128
CQG WebAPI | Disconnected. | 2021-02-11 21:44:26.129
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:26.129
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:44:29.140
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:44:29.140
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:44:29.141
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:44:29.142
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:44:29.142
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:44:50.191 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:44:50.191
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:44:50.192
CQG WebSocket | WebSocket closed. | 2021-02-11 21:44:50.192
CQG WebAPI | WebSocket closed. | 2021-02-11 21:44:50.192
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:44:50.192
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:50.192
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:44:50.192
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:44:50.206
CQG WebAPI | Disconnected. | 2021-02-11 21:44:50.207
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:44:50.207
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:44:53.217
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:44:53.217
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:44:53.218
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:44:53.218
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:44:53.218
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:45:14.268 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:45:14.269
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:45:14.269
CQG WebSocket | WebSocket closed. | 2021-02-11 21:45:14.269
CQG WebAPI | WebSocket closed. | 2021-02-11 21:45:14.269
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:45:14.269
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:45:14.269
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:45:14.269
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:45:14.285
CQG WebAPI | Disconnected. | 2021-02-11 21:45:14.286
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:45:14.286
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:45:17.297
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:45:17.297
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:45:17.298
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:45:17.299
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:45:17.299
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:45:38.341 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:45:38.341
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:45:38.341
CQG WebSocket | WebSocket closed. | 2021-02-11 21:45:38.341
CQG WebAPI | WebSocket closed. | 2021-02-11 21:45:38.341
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:45:38.341
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:45:38.341
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:45:38.341
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:45:38.357
CQG WebAPI | Disconnected. | 2021-02-11 21:45:38.357
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:45:38.358
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:45:41.348
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:45:41.348
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:45:41.349
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:45:41.349
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:45:41.350
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2021-02-11 21:45:53.509
The message log has been sent to support. | 2021-02-11 21:45:53.509 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2021-02-11 21:45:53.509
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2021-02-11 21:45:53.509
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2021-02-11 21:45:55.610
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2021-02-11 21:45:55.849
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:45:55.849
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2021-02-11 21:45:55.850
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2021-02-11 21:45:56.164
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2021-02-11 21:45:56.164
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:46:02.380 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:46:02.380
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:46:02.380
CQG WebSocket | WebSocket closed. | 2021-02-11 21:46:02.380
CQG WebAPI | WebSocket closed. | 2021-02-11 21:46:02.380
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:46:02.380
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:02.381
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:46:02.381
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:46:02.396
CQG WebAPI | Disconnected. | 2021-02-11 21:46:02.396
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:02.397
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:46:05.398
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:46:05.398
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:46:05.399
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:46:05.399
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:46:05.399
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:46:26.434 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:46:26.434
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:46:26.434
CQG WebSocket | WebSocket closed. | 2021-02-11 21:46:26.435
CQG WebAPI | WebSocket closed. | 2021-02-11 21:46:26.435
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:46:26.435
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:26.435
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:46:26.435
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:46:26.450
CQG WebAPI | Disconnected. | 2021-02-11 21:46:26.450
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:26.451
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:46:29.443
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:46:29.443
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:46:29.444
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:46:29.445
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:46:29.445
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:46:50.475 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:46:50.475
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:46:50.475
CQG WebSocket | WebSocket closed. | 2021-02-11 21:46:50.476
CQG WebAPI | WebSocket closed. | 2021-02-11 21:46:50.476
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:46:50.476
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:50.476
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:46:50.476
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:46:50.491
CQG WebAPI | Disconnected. | 2021-02-11 21:46:50.491
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:46:50.492
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:46:53.494
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:46:53.494
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:46:53.495
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:46:53.495
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:46:53.495
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:47:14.554 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:47:14.555
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:47:14.555
CQG WebSocket | WebSocket closed. | 2021-02-11 21:47:14.555
CQG WebAPI | WebSocket closed. | 2021-02-11 21:47:14.555
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:47:14.555
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:47:14.555
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:47:14.555
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:47:14.570
CQG WebAPI | Disconnected. | 2021-02-11 21:47:14.571
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:47:14.571
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:47:17.571
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:47:17.571
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:47:17.572
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:47:17.573
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:47:17.573
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:47:38.607 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:47:38.607
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:47:38.607
CQG WebSocket | WebSocket closed. | 2021-02-11 21:47:38.608
CQG WebAPI | WebSocket closed. | 2021-02-11 21:47:38.608
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:47:38.608
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:47:38.608
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:47:38.608
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:47:38.622
CQG WebAPI | Disconnected. | 2021-02-11 21:47:38.623
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:47:38.624
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:47:41.618
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:47:41.618
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:47:41.840
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:47:41.840
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:47:41.840
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:48:02.866 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:48:02.866
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:48:02.866
CQG WebSocket | WebSocket closed. | 2021-02-11 21:48:02.866
CQG WebAPI | WebSocket closed. | 2021-02-11 21:48:02.866
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:48:02.866
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:02.866
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:48:02.866
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:48:02.881
CQG WebAPI | Disconnected. | 2021-02-11 21:48:02.882
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:02.882
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:48:05.882
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:48:05.882
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:48:05.883
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:48:05.883
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:48:05.883
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:48:26.912 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:48:26.912
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:48:26.912
CQG WebSocket | WebSocket closed. | 2021-02-11 21:48:26.912
CQG WebAPI | WebSocket closed. | 2021-02-11 21:48:26.912
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:48:26.913
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:26.913
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:48:26.913
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:48:26.928
CQG WebAPI | Disconnected. | 2021-02-11 21:48:26.929
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:26.929
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:48:29.934
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:48:29.934
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:48:29.935
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:48:29.936
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:48:29.936
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-02-11 21:48:50.968 *
CQG WebSocket socket (1) | CloseSocket call. | 2021-02-11 21:48:50.969
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 21:48:50.969
CQG WebSocket | WebSocket closed. | 2021-02-11 21:48:50.969
CQG WebAPI | WebSocket closed. | 2021-02-11 21:48:50.969
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-11 21:48:50.969
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:50.969
CQG WebSocket socket (1) | Closed. | 2021-02-11 21:48:50.969
CQG WebSocket socket (0) | CloseSocket call. | 2021-02-11 21:48:50.970
CQG WebAPI | Disconnected. | 2021-02-11 21:48:50.971
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-11 21:48:50.971
CQG WebAPI | Connecting to server api.cqg.com | 2021-02-11 21:48:53.974
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-02-11 21:48:53.974
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-02-11 21:48:53.975
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-02-11 21:48:53.975
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2021-02-11 21:48:53.975
[2021-02-12 15:59:16]
Refer to:
CQG Trading Platform Service: Frequent Server Disconnections when Using CQG
Since you are using Denali Data Feed you really should use the Sierra Chart Order Routing Service and take advantage of all of its safety features as compared to CQG:
Sierra Chart / Trading Technologies Futures Order Routing Service
You can have then six different servers you can choose from and manage these problems yourself. You can choose for example our server on the West Coast of the US meant for the Asia-Pacific region.
Date Time Of Last Edit: 2021-02-12 16:00:02
