Date/Time: Sun, 23 Feb 2025 09:04:58 +0000
POC Highlight on Numbers Bars
View Count: 1091
[2021-02-12 15:03:07] |
User275592 - Posts: 97 |
Hi, with all the parameters you offer on Numbers Bars, I have been able to design exactly what i wanted ! exxactly but a detail : being able to show the POC Highlight in: (yellow box) on a candlestick outline in:74 Whren the POC is at the low or high price of the body, the POC highlight is not correctly displayed (it is partially overwrote (sorry for my english) by the candle) Thank you for your help Renaud |
[2021-02-12 16:30:18] |
John - SC Support - Posts: 38116 |
One or the other has to be overwritten. What we would recommend you do is increase the size of the POC highlight. This should give you what you want. Refer to the setting here: Numbers Bars: Point Of Control Highlight Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
