Date/Time: Sun, 23 Feb 2025 09:03:36 +0000
Current Price
View Count: 701
[2021-02-12 14:07:16] |
Ben A - Posts: 123 |
Hi, How can I go to current price in the chart quickly without scrolling? Sometimes my charts will go to a random price and it will take a long time to scroll up/down manually. Many thanks, |
[2021-02-12 15:29:20] |
Use these commands: Chart Menu: Goto End of Chart (Chart menu) Chart >> Scales >> Reset Scales You can also add Control Bar buttons for these: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
