Date/Time: Tue, 25 Feb 2025 19:56:23 +0000
[User Discussion] - MESH21-CM
View Count: 504
[2021-02-12 11:54:39] |
58LesPaul - Posts: 429 |
I show 2 different symbols in my Trade Activity Log for SIM. MESH21-CM and the typical MESH21. What does the CM mean?
[2021-04-30 08:12:56] |
The correct symbol is: MESH21-CME The other symbols you mention are either incorrect or old. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
