Date/Time: Sun, 23 Feb 2025 08:40:32 +0000
[User Discussion] - NBCV - subgraphs order
View Count: 686
[2021-02-12 10:47:37] |
IC2021 - Posts: 8 |
HI there, Is there any way to move the Volume row (SG2) above Delta row (SG1) . Please see the attached photo. Thanks |
[2021-02-12 11:17:16] |
User907968 - Posts: 832 |
Numbers Bars: Numbers Bars Calculated Values Input Descriptions Subgraph Display Order: This study Input provides a means by which the available Calculated Values rows can have their display order changed. This Input is a comma separated list of study Subgraph numbers (1, 2, 3, ...). By default this Input is blank, which displays the rows in the default order. This is according to the position a particular Calculated Value is at in the list of Subgraphs on the Subgraphs tab of the Study Settings window for the Numbers Bars Calculated Values study. By entering a list of Subgraph numbers for this Input, those Subgraphs will be displayed in the specified order. Any Subgraphs set with a Visible Draw Style not specified in the list, will be displayed after those specified.
