Date/Time: Mon, 25 Nov 2024 17:30:26 +0000
Unable to receive TICK-NYSE data
View Count: 1023
[2014-02-25 18:03:03]
User76539 - Posts: 18
Hi there,
I have updated my SC to 1097 and replaced $TICK by TICK-NYSE Market stats. Unfortunately I do not receive any data from TICK-NYSE.
Can you help me pls.? My broker is InteractiveBrokers.
mirek
attachmentSC_log.txt - Attached On 2014-02-25 18:01:13 UTC - Size: 80.36 KB - 396 views
[2014-02-25 18:09:32]
For some reason you are not getting the symbol settings for the market statistics symbols.
Update the Global Symbol Settings as explained in this section here:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
[2014-02-25 18:28:37]
It is fixed now. Update Global Symbol Settings helped.
Thank you a lot for your quick fix.
mirek
