Date/Time: Sun, 23 Feb 2025 08:56:46 +0000
Problems with replay
View Count: 531
[2021-02-12 08:31:45] |
g4500 - Posts: 27 |
Hi When i m trying to do replay,it only work in one of the window of the chartbook , for example the graph work , but nt the footprints, the dom... When i select the date i alway select the options " in all chartbooks " but still not working. Is that normal? |
[2021-02-12 10:25:45] |
It may be a problem with not enough data loaded in the other charts/Trading DOMs being replayed. Go through the instructions here for replaying a Trading DOM: Replaying Charts: Replaying Trade DOM Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-12 11:14:16] |
g4500 - Posts: 27 |
Thank s for your answer. I have the same issue with footprints,weekly and monthly vwap. It s the same process? |
[2021-02-12 11:30:29] |
Yes most likely: Replaying Charts: All Charts in Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
