Date/Time: Sun, 23 Feb 2025 08:47:21 +0000
Stand alone OCO (no parent)
View Count: 542
[2021-02-12 03:58:26] |
User621507 - Posts: 2 |
I am new to the platform but I am quickly getting used to it. One thing I'm having trouble with is being able to create an OCO order independent of a parent order. Specifically, I would like to set a "break out" bracket; one that will set a buy stop below and above the market price. Another, example would be creating an exit bracket for an open position without having to add to the position (i.e. limit/stop with no parent order.)
[2021-02-12 10:27:18] |
User877753 - Posts: 152 |
Hi, For OCO entry : Order Types: OCO Limit and Stop For exit bracket order on the fly : Order Types: Send Attached Orders - Position/Price JM |
[2021-02-12 10:40:23] |
All the different OCO order types are documented here: Order Types You may be interested in this one: Order Types: OCO Buy Stop Sell Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-12 10:50:09] |
I'm able to do it for sell orders but not buy, am I missing something again? It's a buy stop order above market and a buy limit below, in theory
Date Time Of Last Edit: 2021-02-12 11:20:53
