Date/Time: Sun, 23 Feb 2025 08:29:54 +0000
High & Low on Daily vs. High & Low on 5 minute
View Count: 461
[2021-02-12 02:52:53]
58LesPaul - Posts: 429
A new bar started this evening on 2-11, seems it was around 18:30 for some reason. In the daily chart you can see the high and low for this new 21-02-11 bar. But if you look at the 5 minute bar I have the crosshair on 3906.00, which is what the daily says is the low. The low since 15:00:00 today is 3903.25. The high on the daily shows 3911.50 but on the 5 minute chart the high is 3914. Why are these not the same? But when I look at the day before, 2021-02-10, the high and low match.
Private File
Private File
[2021-02-12 03:11:38]
Never mind, I went to Delete All Data and Download and that fixed it.
