Date/Time: Mon, 10 Mar 2025 17:13:56 +0000
DTC Protocol and EUREX ObO/MbO
View Count: 898
[2021-02-12 00:16:05] |
Mighty7 - Posts: 5 |
Hi, has the DTC Protocol the EUREX ObO/MbO already fully implemented? Thanks. |
[2021-02-12 10:40:47] |
No not yet.
[2021-02-15 09:13:40] |
Thank you for the answer. Is there a time frame for this? Without DTC I can't use it.
[2021-02-22 12:27:57] |
Or is there an other option to get the Denali Eurex feed outside of Sierra Chart?
[2021-02-22 13:58:36] |
Is there a time frame for this? Without DTC I can't use it. We cannot say at this time.Or is there an other option to get the Denali Eurex feed outside of Sierra Chart? This would be accessible through the DTC protocol server in Sierra Chart, but if you need the individual orders, this is not yet available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 13:58:43
[2021-03-17 09:06:01] |
Hello, since the feed now seems to be going well, is it foreseeable when the DTC protocol will be fully implemented? I need the individual orders and the order book.
[2022-04-07 08:32:17] |
Is this now working with full EUREX EOBI market data depth?
[2022-04-07 09:45:14] |
EUREX data is fully disallowed through the DTC protocol server. We cannot allow this data due to exchange rules and we do not want to run into any risk with violation of the rules by one of our users. Sorry there is just nothing further we can do.
