Date/Time: Thu, 11 Jun 2026 19:19:39 +0000
[Programming Help] - error: 'structs_sc' has no member named 'PersistVars'
View Count: 946
[2021-02-11 19:14:22]
User61576 - Posts: 453
I am trying to compile this code here:
Delta Divergence Source Code -- Does Not Compile
and getting an error:
In function 'void scsf_DeltaDivergence(SCStudyInterfaceRef)':
error: 'struct s_sc' has no member named 'PersistVars'
and the line is
int& inTrade = sc.PersistVars->i1;
as far as I understand (since SC team didn't fix it but only sent the user to an older version) this is a call for the current position
is there any other way to call the current position?
[2021-02-11 20:18:58]
User907968 - Posts: 872
You need to replace sc.PersistVars with sc.GetPersistentInt, https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetPersistentInt.
