Date/Time: Tue, 04 Mar 2025 21:19:08 +0000
Roll All Symbols in Instance
View Count: 1019
[2021-02-11 17:41:13] |
User379468 - Posts: 508 |
With a lot of different charts/chartbooks/symbols/watchlists, how can one simply roll all symbols simultaneously to current without doing manually one by one?
[2021-02-11 20:09:40] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2021-02-11 22:09:15] |
I'm in the process of setting up a new account pending the new pricing changes, in the meantime could you let me know the solution to the above?
[2021-02-12 22:17:41] |
For this you need to use Chart Linking: Working With Charts: Chart Linking And refer to: Getting Quotes: Futures Contract Rollover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-12 22:18:16
[2021-02-12 22:30:51] |
Chart linking would not help for many charts with different symbols. Seems you have this for the Quote Board already: "All future symbols in the Quote Board can be rolled over at any time by selecting Settings >> Rollover Futures Symbols Now on the Quote Board menu." Can this feature be implemented also for all charts? |
[2022-01-06 13:31:27] |
skelcap - Posts: 139 |
This would be a helpful feature for me too.
