Date/Time: Sun, 23 Feb 2025 08:39:26 +0000
replay function
View Count: 609
[2021-02-11 00:45:19] |
Timothy Hartnett - Posts: 5 |
Hi, my replay function is not working correctly, it starts playing the chart without showing any historical data. I have been using it before with no problem however I am sharing the chartbook file with my laptop so maybe that is causing a problem?
[2021-02-11 04:13:54] |
First thing to do is to make sure the Use Start Date-Time is unchecked on the replay window. And then follow through the instructions here: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
