Date/Time: Sun, 23 Feb 2025 08:59:30 +0000
[User Discussion] - Daily Low and High
View Count: 604
[2021-02-10 22:16:21]
58LesPaul - Posts: 429
I tried the Daily OHLC study but it just shows the High and Low for that day and stops when a new day starts. Is there anyway to extend past that day into the current day? Or another study that will do that?
[2021-02-11 03:47:10]
Sawtooth - Posts: 4174
In the Daily OHLC study settings, set the 'Reference Days Back' to 1.
Daily OHLC
[2021-02-11 10:35:40]
I didn't explain that well. I want the lines for yesterdays high and low to continue and extend into today and keep extending until I decide to remove it. Now they only put a line for H and L on that single day. I believe it can only be done by drawing manually.
Thnaks
[2021-02-11 13:56:19]
...and keep extending until I decide to remove it.
Since this is a condition, drawing it manually is probably the best way, because you could have an unknown number of 'yesterday's' lines extending.
[2021-02-11 14:05:02]
You can limit the days to one or whatever you want but it still only paints it for that day alone.
